eric testing notes / findings /suggestions etc
Home › Forums › Vectorblade beta test › eric testing notes / findings /suggestions etc
Viewing 3 posts - 1 through 3 (of 3 total)
  • #3312
    Hurray Banana
    Played a little tonight using beta 6 so not touching on bugs. Will try the latest build (16 currently) and do extended play tomorrow.
    On the high score entry you have to select 3 initials, there is no way for someone with just two to enter two and leave a space or .
    HB not possible for me, so end up putting HBA like I have to do in berzerk. Picky I know. If there was a symbol character, way of entering a space (underline, or some such to represent a space on entry) it would be good.
    <!–more–><!–more–>
    #3313
    Hurray Banana
    Just had a quick play of beta16, you’ve got a space now !!
    Probably needs instructions I didn’t realise you had to shoot the letters !
    Did have a confusion in shop, tried to buy bullet 2, but wouldn’t take my money? don’t know why, but did let me spend lots of bullet 1, don’t know what the consequence of that is.
    https://1drv.ms/u/s!AnPHAdPvv8fFkLJYZL3VO2TQjw04aw
    #3314
    Ah… the shop.
    Yes – that is a bug, will be fixed with the next beta…
