Nico testing notes / findings / suggestions etc
Home › Forums › Vectorblade beta test › Nico testing notes / findings / suggestions etc
Viewing 5 posts - 31 through 35 (of 35 total)
  • #3646
    Gz btw… 👍
    #3647
    nic_lobo
    Minestorms can be used to skip levels – if luck has it right – you can skip even boss levels.
    The shop is integral part of the level played before. If you skip the end of the level – you skip the shop.
    But most of the time you are able to chose for youself, which route you’d like to take…
    o.k. understood. So I could also skip the last boss? Feels strange.
    Gz btw… 👍
    means gratulations I assume … thx 🙂
    #3808
    nic_lobo
    beta 26
    did not play so much the last days, but got till level 75.
    it’s getting much harder to get money/extras in the higher levels. So it is really difficult to recover from getting shot.
    When losing the last life there is this screen where the final score is calculated. It would be nice if it would stay a bit longer, or would wait for a key press to have the time to write the score down when competing with friends.
    Would also be great if the last level number would be written on that screen.
    #3809
    Right, atm counting is very fast and you cannot really see what is counted unless you know it. It would be good if the initial score/number/rank was shown for a short while and then counting down begins.
    #3812
    I’ll look into it.
    I have found a few other things, that need fixing too…
