May 13, 2019 at 10:45 pm #2933
KeymasterVectorblade_Beta1.bin – 14th Mai 2019
Vectorblade_Beta2.bin – 15th Mai 2019 (Fix: music, shot brightness, bug HP)
Vectorblade_Beta4.bin – 19th Mai 2019
Vectorblade_Beta5.bin – 19th Mai 2019 (Added many sounds, fixed button/noise bug, added Warp Failure no spawn on easy, big enemies give more points, started game over sequence, perhaps fixed rank marker secret)
Vectorblade_Beta6.bin – 19th Mai 2019 (Fixed a bug, where a crash occurred when defeating the last boss, started Highscore editing again…)
May 20, 2019 at 2:14 pm #3025GeoAnas
SpectatorGot them, all. Thanks!
I am still on hold for the special cart, I will start to report back when I receive it.
May 20, 2019 at 7:33 pm #3027Malban
KeymasterVectorblade_Beta7.bin – 20th Mai 2019
– fixed a bug, where a crash could occur with a 4 shot weapon.
– added all bonus “explanations” to desktop
– added “demo mode” to titel screen (long wait)May 21, 2019 at 9:42 pm #3041Malban
KeymasterVectorblade_Beta8.bin – 21th Mai 2019
– bug fix with “wild vectors” found by VTK
– bug fix for intro… man stays on screen, intro bonus do not vary in brightness
– Bugs have double hitpoints on easy…May 21, 2019 at 9:49 pm #3042vtk
Spectatorhey thanks for the beta 8 change; i really wanted to try those bugs with harder difficulty as i have found them so weak and helpless before haha, so i know it will be much better now, thanks very much for that change!
May 22, 2019 at 8:56 pm #3065Malban
KeymasterVectorblade_Beta9.bin – 21th Mai 2019
– fixed the different brightness levels in intro screen
– enabled “difficulty” select in “options” if you want to try
– 3 second wait in boss intro
– dunno there was something small, ive forgottenNo big update…
This reply was modified 7 years, 6 months ago by
May 22, 2019 at 10:17 pm #3068vtk
SpectatorVectorblade_Beta9.bin
thanks, i will play tonight (as usual) 🙂
May 23, 2019 at 6:15 pm #3072Peer
SpectatorGot it, thanks!
May 25, 2019 at 4:44 am #3129GeoAnas
SpectatorGot it, thanks! Since I haven’t got yet the special cart, I am thinking to start testing it via VecFever.
EDIT: …obviously not that easy as a simple drag ‘n drop. Have to ask Thomas about (just read Malban’s welcome post) 🙂
GeoAnas.
May 25, 2019 at 3:13 pm #3135Malban
KeymasterVectorblade_Beta10.bin – 25th Mai 2019
– bug fix of crash possibilty, probably the one vtk reported with the big alien
– started “stars” in high score edit, also changed the high score font
– calibration: button 4 next calibration, joystick coarse tune calibration, button 1+2 fine tune calibration
– “arrows” on the desktop are slightly brighter– dunno there was something small, ive forgotten
May 28, 2019 at 9:55 pm #3179Malban
KeymasterVectorblade_Beta11.bin – 28th Mai 2019
– bug fix in demo mode
– highscore edit “nearly” done, actually the edit is done, the viewer must be finalized. Calibration for Highscore not correct. In highscore edit butten 4 “shoots” the next letter, button 3 accepts the current letter without shooting.
– bugfix: scoopy secret jingle was played more than once
– brightness of desktop again slightly changed
– demo mode, armor and scoopies can not be collected (otherwise a “death” would be possible)known “features”:
– achievements scroll to fast
– calibration overall must be revamped and applied
– some sounds are still missing
– highscore must be finalized
– bomb is buyable after “simple” secret, should be buyable only be “the other” secretJune 3, 2019 at 5:13 pm #3251Malban
KeymasterVectorblade_Beta13.bin – 3rd June 2019
– high score finished (edit + show), awaiting comments 🙂
– added Helmuts DRAFT #2 as desktop “theme”
– title screen (for now) has a “PRESS BUTTON” (exits on button press – or when music finishes playing)
– some bugfixes I can’t rememeber
– rearranged some memory (between banks)
– @Helmut: could not find your “Game Over” problemIf anyone wants a *.V4E file for VecFever + IRQ lines -> tell me.
June 3, 2019 at 10:51 pm #3268vtk
Spectatornice, i will have a go of beta13 now and report in soon
June 4, 2019 at 7:29 pm #3290Malban
KeymasterVectorblade_Beta14.bin – 4rd June 2019
– high score shows now 8 aliens (btw – really like the high score music)
– title screen fades in, then scrolls up and vectorblade comes in (awaiting new music, then it will finish with the music, for now press button)
– added some more sounds to the gameNext will be the whole calibration overhaul, including extra settings for “no buzz” machines (but not today 🙂 )
June 4, 2019 at 7:38 pm #3291vtk
Spectatorthanks very much im going to try this new beta right now then will report back
ps. there is a bit of a delay with the galaga music as i had to check the volumes, but i should have that sorted out later tonight
